Вышла новая версия программы Daz3D Bryce 6.1 .
Что нового в новой версии программы ? Вот, что говорят разработчики :
What's New in 6.1?
MAC-Intel compatibility (Bryce 6.1 runs up to 50% faster natively on the Intel based MAC's as opposed to running under Rosetta).
New controls for the IBL pane within the Sky Lab added. Now you can rotate the HDR image around your scene and have greater control over the Quality, Intensity, HDRI Effect, Radius, and Falloff of the HDRI light maps.
Optimized and improved the HDRI algorithms for greater accuracy and overall color correctness.
Plus, now you can set the priority for Bryce's CPU usage (Low, Normal and High). This allows you to determine whether Bryce runs at maximum capacity or at a more restrained rate to allow you to more easily work with other CPU intensive apps at the same time. With this feature, you can have Bryce 6.1 run 170% faster than under Rosetta.
Ten new HDRI light probes are included for use with Bryce 6.1.
Important updates and fixes to included content.
Greater stability through some important bug fixes, particularly with the Bryce Lightning Network Render application.
В основном изменения коснулись настроек окна HDRI. Но эти изменения существенно улучшили получаемые результаты визуализации. Вот некоторые примеры.
What's New in 6.1?
