!!!!!new!!!!!!!! Vray Build 1.47.02 !!!!!new!!!!!!
Build 1.47.02 - 11 May 2005:
Modified features:
* VRayProxy objects are now treated as bitmaps so that they can be exported along with the rest of the scene.
* If the Secondary rays bias is 0.0 in texture baking mode, VRay will automatically adjust this to 0.001 to avoid errors.
Extended features:
* New parameter Anisotropy added to the DOF parameters. This allows the stretching of the bokeh effect horizontally or vertically.
* Added a hidden parameter system_vrayLog_ccToDebugger to allow redirecting the VRay log to the 3dsmax log file.
* Added a hidden parameter system_vrayLog_numThreads for manual control of the number of rendering threads.
* Added a new parameter Blur GI to the Irradiance map parameters with the purpose of reducing flickering of GI in animations with moving objects.
Bug fixes:
* Hair in 3dsmax 7.5 in buffer mode did not render in camera views.
* Complex materials (Blend, Shellac) and the falloff map with shadow/light mode did not work in path tracing mode.
* Highlights were not computed in the Progressive path tracing Mode of the Light cache.
* Zooming and panning in the 3dsmax VFB could crash 3dsmax.
* Multi/sub materials with some shader types could render with wrong brightness.
* Interpolated glossy reflections didn't work with Multi/sub material.
* Crashes with displacement and motion blur when the displacement map used Object XYZ mapping.
* Crashes during building the irradiance map with Overlapped Look-up mode when Interp. samples not divisible by 4.
* When the Override mtl button is clicked, the Material Browse dialog is opened twice in 3dsmax7.
* In track view, the parameter names for VRayDisplacementMod were wrong.
* The Hilbert curve generator crashed if the region size is larger than the rendered region.
* Rare crashes with dynamic geometry (displacement etc) when it needed to be unloaded from memory.
* Objects with Visible to camera off were visible in the z-buffer.
* Spots with back-facing UVW triangles in texture baking mode.
* Planar from object XYZ mapping mode did not work with motion blur enabled.
* The Ward BRDF in the VRayMtl could cause red dots in the scene.
* Missing UVW coordinates could cause splotches in the scene.
* The VRayHDRI map with Angular Mapping type could produce invalid colors.
* Crashes with subdivision/displacement when they were applied to both moving and static objects in a scene with motion blur on.
* The texture channel for anisotropy was not working.
* When Switch to saved map is on, VRay switched to From file Mode even when GI is off.
эта тема находится в systems. никак не вьеду как она работает. кто знает?
aramdi
А на кой оно теб надо то? В этом списке перечислены варианты прохода картинки при рендере. Там, конечно, есть свои внутренние плюсы-минусы, но большого значения это не имеет. Базар о том, что есть такой баг: при просчете картинки по кривой этого Гилберта, если используется Render Region, и он больше размером, чем размер твоего Вьюпорта, Макс может слететь. Это очень существенно?
2aramdi : надо мне это для того чтоб таких вопросов больше не возникало. что находится в этом списке я знаю. но вот как работет именно кривая гилберта для меня загадка. что значит больше вьюпорта? какой смысл в этом всё равно то что выходит за пределы считаться не будет. какие ещё у кого версии?
Modified features:
Внесенные изменения:
Теперь оъекты VrayProxy обрабатываются как растр, таким образом, они
могут экспортироваться вместе с остальной сценой.
Если параметр смещения вторичных лучей выставлен 0.0 в режиме texture
baking, Vray автоматически исправит его на 0.001, чтобы избежать
ошибок.
Extended features:
Расширенные параметры:
Новый параметр «анизотропия» добавлен к параметрам DOF. Это позволяет
растянуть bokeh effect горизонтально или вертикально.
Добавлен скрытый параметр system_vrayLog_ccToDebugger, который
позволяет перевести запись Vray в файл 3дмакс.
Добавлен скрытый параметр system_vrayLog_numThreads для ручного
контроля за количеством визуализируемых объектов.
objects.
Добавлен новый параметр Blur GI к параметрам Irradiance map,чтобы
уменьшить мерцание GI при анимации движущихся объектов.
Bug fixes:
Исправленные баги:
Волосы в 3дмаксе 7.5 в «режиме буффер» (гыгы) не визуализируются в
режиме камера вью.
Составные материалы (Blend, Shellac) и карта типа фаллофф с режимом
тень/свет не работают в режиме path tracing.
the Light cache.
Подсветка не работает в режиме Progressive path tracing Light cache.
Зум и пан в 3дмакс VFB может снести 3дмакс.
brightness.
Multi/sub materials с некоторыми типами шэйдеров может визуализировать
с неправильной яркостью.
Интерполяция glossy reflections не работает с Multi/sub material.
Не работает при displacement и motion blur, когда карта displacement
использует Object XYZ mapping.
Не работает при построении irradiance map с режимом Overlapped
Look-up, когда сэмплы интерполяции не делятся на 4.
При нажатии кнопки Override mtl в 3дмаксе дважды открывается окно
материалов.
wrong.
В режиме track view названия параметров для VrayDisplacementMod
неправильны.
Рендеринг по кривой Гилберта не работает при визуализации региона,
если размер выделенного региона превышает размер окна Вьюпорта
Реже не работает с динамической геометрией (displacement и т.д.),
когда не надо загружать из памяти.
Объекты с отключенным режимом видимости для камеры были видны в
z-buffer.
Пятна с back-facing UVW triangles при режиме texture baking.
enabled.
Плоскостной для объектов режима XYZ mapping не работает при включенном
режиме motion blur.
Затенение по Варду в VrayMtl может вызвать появление красных точек в
сцене.
При пропуске координат UVW в сцене могут появиться блики.
colors.
Карта VRayHDRI с ангулярным типом наложения карты может выполнить
неправильную цветопередачу.
Не работает с режимами subdivision/displacement, когда они применяются
сразу и к движущимся и к статичным объектами в сцене с включенным
режимом motion blur.
Канал текстуры для анизотропии не работает.
when GI is off.
Когда включен режим сохранения карты, Vray загружает карту из файла,
даже когда GI режим отключен.
Нармальна я свой ник написал ..
Переводил не я - я немного консультировал , в общих чертах и по Английски было понятно , но вдруг кому-то НАДО ПА РУССКИ
