Не ставится max 2015
Тема в разделе "Общие вопросы", создана пользователем awol, 14 дек 2014.
  1. awol
    awol Активный участник
    Собственно, и 2014 не ставится. Выдает ошибку:
    2014/12/13:17:01:04 awol AWOL-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): "H:\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\awol\AppData\Local\Temp\vcredist_x86_2005.log"" "
    2014/12/13:17:01:07 awol AWOL-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
    Почитал пр онее в инете, все проверил, скачал последний Micriosoft Visual - не помогает.
    Стал смотреть лог файл,вот его кусок:
    ******* Product: C:\Users\awol\AppData\Local\Temp\IXP000.TMP\vcredist.msi
    ******* Action:
    ******* CommandLine: **********
    MSI (s) (54:3C) [17:01:07:506]: Machine policy value 'DisableUserInstalls' is 0
    MSI (s) (54:3C) [17:01:07:522]: User policy value 'SearchOrder' is 'nmu'
    MSI (s) (54:3C) [17:01:07:522]: User policy value 'DisableMedia' is 0
    MSI (s) (54:3C) [17:01:07:522]: Machine policy value 'AllowLockdownMedia' is 1
    MSI (s) (54:3C) [17:01:07:522]: SOURCEMGMT: Looking for sourcelist for product {837b34e3-7c30-493c-8f6a-2b0f04e2912c}
    MSI (s) (54:3C) [17:01:07:522]: SOURCEMGMT: Adding {837b34e3-7c30-493c-8f6a-2b0f04e2912c}; to potential sourcelist list (pcode;disk;relpath).
    MSI (s) (54:3C) [17:01:07:522]: SOURCEMGMT: Now checking product {837b34e3-7c30-493c-8f6a-2b0f04e2912c}
    MSI (s) (54:3C) [17:01:07:522]: SOURCEMGMT: Attempting to use LastUsedSource from source list.
    MSI (s) (54:3C) [17:01:07:522]: SOURCEMGMT: Source with value name '2' is blank
    MSI (s) (54:3C) [17:01:07:522]: Note: 1: 1706 2: -2147483647 3: vcredist.msi
    MSI (s) (54:3C) [17:01:07:522]: SOURCEMGMT: Processing net source list.
    MSI (s) (54:3C) [17:01:07:522]: SOURCEMGMT: Processing media source list.
    MSI (s) (54:3C) [17:01:07:522]: SOURCEMGMT: Trying media source H:\.
    MSI (s) (54:3C) [17:01:07:522]: Note: 1: 2203 2: H:\vcredist.msi 3: -2147287038
    MSI (s) (54:3C) [17:01:07:522]: SOURCEMGMT: Source is invalid due to missing/inaccessible package.
    MSI (s) (54:3C) [17:01:07:522]: SOURCEMGMT: Processing URL source list.
    MSI (s) (54:3C) [17:01:07:522]: Note: 1: 1402 2: UNKNOWN\URL 3: 2
    MSI (s) (54:3C) [17:01:07:522]: Note: 1: 1706 2: 3: vcredist.msi
    MSI (s) (54:3C) [17:01:07:522]: SOURCEMGMT: Failed to resolve source
    MSI (s) (54:3C) [17:01:07:522]: MainEngineThread is returning 1612
    MSI (s) (54:BC) [17:01:07:522]: User policy value 'DisableRollback' is 0
    MSI (s) (54:BC) [17:01:07:522]: Machine policy value 'DisableRollback' is 0
    MSI (s) (54:BC) [17:01:07:522]: Incrementing counter to disable shutdown. Counter after increment: 0
    MSI (s) (54:BC) [17:01:07:522]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
    MSI (s) (54:BC) [17:01:07:522]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
    MSI (c) (88:B8) [17:01:07:522]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
    MSI (c) (88:B8) [17:01:07:522]: MainEngineThread is returning 1612
    === Verbose logging stopped: 13.12.2014 17:01:07 ===
    Камрады, что там умного написано?
    Уж очень не хочется сносить винду (и с десяток программ) и все заново ставить с нуля..
  2. maiden666
    maiden666 Мастер
    одним словом - запретить установку Си
    Open Setup.ini in the Autodesk product folder
    Comment out these pairs of lines: (by adding a "#" in front of each line)
    EXE_PARAM=/q
    VC_FUNC=VCx64RedisCheck
    EXE_PARAM=/q
    VC_FUNC=VCx86RedisCheck
    During the installation, Microsoft installers will now pop up. Select "repair" in both cases, and make sure everything goes well. If one of the installers fails, cancel the Autodesk installation and solve the problem the installer had.
    What this does is prevent the Autodesk installer from checking if the VC++ packages are correctly installed.This is a solution only if (as it was in my case) the check reports a false negative. If you really have problems with your VC++ installation, it might be a good idea to reinstall Windows.
    If you still don't get past the VC++ installation (but you are sure your installation is ok), you might also want to comment out this block:
    EXE_PARAM=/q /l %temp%\vcredist_x86_2010.log
