Появилась новая версия классного Extension-а:
http://www.highend3d.com/maya/mel/?section=rendering&sort=dt_modified+desc#2132
"Render View button modifications and extended functionality:
- Both "Render Frame" and "IPR Render" buttons are modified to have a camera selection popup menu when clicking with the right mouse button.
- The scene preparation and render time is displayed at the bottom of the renderView after rendering a frame.
- A new Snapshot button added, with the usual right button camera selection menu.
- Render Diagnostics button is removed since it is in the upper menu and its a rarely used tool. (And we need space for panel mode.
- Color button is extended with a right click menu for all the available display types. (Color/Alpha/R/G/B/Luminance)
- Alpha button removed. Now left clicking the Color button toggles color and alpha channel display.
- Right clicking on the Render Globals button brings up a menu to set things without opening the clumsy Render Globals Window:
Raytracing on/off
Render All / Selected only
Render Quality (Containing user presets)
Motion Blur (off/2d/3d)
Render options (Use Default Light on/off, Depth-Map Shadows, Composite (No premultiply), Paint Effects render, Oversample Paint Effects
Turn All Image Planes on/off (either at once or only at render time)
Select Active (renderable) Camera and set Output Channels (Color/Alpha/Depth)
Image Format (including user defined image formats if there is any defined in the userImageFormats.mel)
+ in case of Mental Ray:
Final Gathering-, Global Illumination-, Caustics-, Displacement on/off
Approximation editing: create, assign and edit approximations from the render view.
(Works with any number and any type of selected objects)
Translation Verbosity
When choosing a different MR render quality preset switches like raytracing and FG remain the same (only the values change).
- Framestore button:
Set Render-info display - GUI to set what kind of information should be displayed at the bottom of the RenderView
Open the mayaImageTool Window - GUI to modify image names, check and compare rendered data, save images and add comments.
Auto-open the mayaImageTool window - Checkbox to automatically open the mIT window after a render.
Add note to rendered image - Renders user defined information on the bottom of the image.
(Date is added as Year/Month/Day)
Save kept images to disk - Option box lets you define a specific filename instead of the current image name set in the render globals.)
Load previously saved images from disk
Delete previously saved images from disk
Remove all images from RenderView
- Preview Resolution button to quickly display and modify the test resoluion. (with a new 75% resolution option)
- Ray Tracing On/Off button that displays the current state of raytracing.
Right clicking this button brings up a new marking menu to set Mental Ray sampling parameters directly, like
easily multiply/divide all the sampling contrast values together.
- The Renderer selection menu has new menuitems to load the currently unloaded renderers.
Render Utilites (a new menu in the renderView):
- "Render Multiple Frames" lets you render any number of different images (or image region)
into the Render View or directly to disk. You can generate sequences based on start frame/end frame/step count
or add frames manually and assign a new camera to any frame.
(This camera will be used until you define a new one in the list.)
You can easily render many frames using different cameras for preview, check animation key positions
or render a whole animation within Maya. (This is slower than batch mode but it can fix render
problems that are known to happen sometimes while using mayabatch.
Read button annotations for further details.
- "Display Mental Ray Tesselation" renders the wireframe image of the selected object(s). This feature displays
the effect of the currently assigned approximations. (Because of a current limitation of the script,
please only select one displaced object at a time. Non-displaced objects work ok, no matter how many of them
you select.) The render uses the current resolution with min=max=0 sampling, and the basic mental ray
contour calculation method to avoid installing custom shaders.
Вобщем - СУПЕР вещица - рекомендую.
