Moderatorial: Пожалуйста, не плодите и не множьте тут варезные темы. Это в конце-концов не варезный форум. Нижеприведённую информацию можно было бы запостить и в первый тред.
На всякий случай решил продублировать тему, затронутую в Черепашьем форуме mirabeau:
"Turtle 2 Release candidate 2 was just released. Please download it from
http://www.illuminatelabs.com/support.asp
See below for release notes:
Bug fixes:
* Made texture loading more memory efficient.
* Fixed crash bug with texture filtering.
* More efficient file loading.
* Fixed transparency issue in Ocean shader.
* Fixed shared fg / occ / photon map file locking issue.
* Fixed Linux / Mac surface transfer crash bug.
* Fixed Ocean Material crash bug.
* Fixed memory leak due to NURBS and instance updates in animation.
* Suppressed creation of light profile attributes for all nodes except point lights.
* Fixed problem with flipped normals, reflections and FG.
* Fixed crash bug with animated visibility.
* Fixed shadow color bug.
* Fixed "look through selected" problem.
* Fixed problems with occlusion baking.
* Fixed crash bug with "Large Scene" and baking.
* Fixed problems with repeated and tiled displacement textures.
* Fixed bug with TIFFs and associated alphas.
* Fixed bug with the projection node's alpha channel.
* Removed annoying popup when running out of memory on Windows.
Improvements:
* Added surface thickness node.
* Added advanced settings for ray tracing.
* Added support for Maya Cloth cache in batch rendering
вот лекарство бы ещё...
Присоединяюсь...
// Велика вероятность того, что она работает и под 7-кой
Bests.
Bug fixes:
Improvements:
Присоединяюсь...
Bests.
