Maya и VRay
GooDroN
Бодрый день!
Проблема... VRay не рендерит анимацию, как только ставишь галку в настройках рендера. (((
Если кто сталкивался, помогите советом пожалуйста. СПАСИБО!!!
P.S. "Render the current frame работает прекрасно"....
GooDroN
Ругается подобным образом...
Initializing V-Ray for Maya
File read in 1 seconds.
Error: Unable to import Adobe(R) Illustrator(R) file : I/O error.
Warning: Can't perform polySoftEdge2 on selection
Result: C:/001/New_Project/scenes/GLASS_BALL_v9__6084.mb
V-Ray: Starting render
[2010/Nov/3|15:47:07] V-Ray: Loading plugins from "C:\Program Files\Autodesk\Maya2011/vray/vrayplugins/vray_*.dll"
[2010/Nov/3|15:47:09] V-Ray: 92 plugin(s) loaded successfully
[2010/Nov/3|15:47:09] V-Ray: Finished loading plugins.
[2010/Nov/3|15:47:09] V-Ray: Exporting scene to V-Ray.
[2010/Nov/3|15:47:09] V-Ray: Parsing light links time 0h 0m 0.0s (0.0 s)
[2010/Nov/3|15:47:09] V-Ray: Translating scene geometry for V-Ray
[2010/Nov/3|15:47:09] V-Ray: (Estimated time remaining: 0h 0m 0.1s): 52 % completed
[2010/Nov/3|15:47:09] V-Ray: Total time translating scene for V-Ray 0h 0m 0.1s (0.1 s)
[2010/Nov/3|15:47:09] V-Ray: Rendering.
[2010/Nov/3|15:47:09] V-Ray: Pre-render export.
[2010/Nov/3|15:47:09] V-Ray: Pre-render export done.
[2010/Nov/3|15:47:09] V-Ray: Rendering frames.
[2010/Nov/3|15:47:09] V-Ray: Updating frame at time 151.00
[2010/Nov/3|15:47:09] V-Ray: (Estimated time remaining: 0h 0m 0.0s): 73 % completed
[2010/Nov/3|15:47:09] V-Ray: (Estimated time remaining: 0h 0m 0.0s): 91 % completed
[2010/Nov/3|15:47:09] V-Ray: Total time updating frame 0h 0m 0.2s (0.2 s)
[2010/Nov/3|15:47:09] V-Ray: Preparing renderer...
[2010/Nov/3|15:47:09] V-Ray: Preparing scene for rendering...
[2010/Nov/3|15:47:09] V-Ray warning: Camera FOV is too small, possible round-off errors.
Warning: Camera FOV is too small, possible round-off errors.
[2010/Nov/3|15:47:09] V-Ray: Preparing scene for frame...
[2010/Nov/3|15:47:09] V-Ray: (Estimated time remaining: 0h 0m 0.0s): 17 % completed
[2010/Nov/3|15:47:10] V-Ray: Compiling geometry...
[2010/Nov/3|15:47:33] V-Ray error: Exception [module=1] : Memory allocation failure; 128 bytes requested; 13421415 bytes already in heap; 624160 bytes free heap space.
Error: Exception [module=1] : Memory allocation failure; 128 bytes requested; 13421415 bytes already in heap; 624160 bytes free heap space.
[2010/Nov/3|15:47:33] V-Ray error: There was a fatal error rendering the scene.
Error: There was a fatal error rendering the scene.
[2010/Nov/3|15:47:33] V-Ray: Render interrupted
[2010/Nov/3|15:47:33] V-Ray: ========================
[2010/Nov/3|15:47:33] V-Ray: Clearing exporter memory...
[2010/Nov/3|15:47:33] V-Ray: Total time clearing exporter memory 0h 0m 0.0s (0.0 s)
Scene C:/001/New_Project/scenes/GLASS_BALL_v9__6084.mb completed.
Болач
Никто не дружит тут с Vray?
Установил Vray и в интерфейсе нет вкладки для вирей с выбором источников солнца и т.д. см. скрииншот.
И другая проблема эт то, что Vray не хочет рендерит в стандарт окне Майи. Лишь в своем окне рендерит.
Vray 3.10 _ Maya 2016
Andots
Читайте мануал по вирею или спросите у гугла, там по vray тонны инфы(google --> How to add vray shelf in maya --> profit). Все что вы описали меняется через render prefences точные координаты ,до пункта и названия, не дам, сейчас vray не стоит а на память не помню. Но все там есть, добавляеться и vray shelf (кажись в группе Vray UI) да и без shelf vray так же добавляет все свои прибамбасы в верхние менюшки Create итп (поищите просто) . Там же в rend pref выбираеться в стд окне или vray frame buffer рендер выводить, там что то типо "use vray frame buffer" насколько помню. Такие вещи вообще лучше в форумах не спрашивать, "не могу найти кнопки", больно долго расписывать, для этого есть мануалы и инструкции в которых все это подробно расписано. Получается история по типу купил телевизор и на форум сразу "Как канал настроить?", а инструкцию почитать с начало не по феньшую видимо. Если уж все прочитали и не нашли тогда сюда, а так смысл писать и ждать ответ, когда на ваш вопрос за 1 секунду поисковик ответ найдет
Болач
У всех в конце рендера кадра идет продолжительная 2-секундная "некая" загрузка непонятно чего?
Это я заметил бывает всегда, если добавить фоновую картину неважно через настройки вирея в энверонмент или через View - Image plane. Даже если картинка лежит просто на фоновом Plane полигоне.
Maya 2016 sp6 / VRay 3.10.01
Andots
Снимаю шляпу. Этож сколько надо врожденной внимательности чтоб заметить "продолжительная 2-секундная "некая" загрузка непонятно чего" ... Ну обычно рендер идет до 36го мартабря. Даже не знаю, мож вражеские агенты что то через фон подгружают. Коды самоликвидации матьплаты со всеми вашими домочадцами к примеру.
Болач
Вообще если быть внимательным как ты говоришь, то там 4 секунд. Для меня это не мелочь т.к. мне например не нравится после рендера ждать несколько секунд так как это не просто значок загрузки, а Мая в этот момент "замирает" пока загрузка не закончится.
И что на этом форуме все какие-то злые сидят, хают всех кто вопросы задают "нафиг тебе Мая если тут то-то.. не трогайте Маю тут все итак идеально.. не переходите на маю если что-то не нравится.."
что за злость в вас не пойму? не трахались давно или что?
Перед каждым вопросом уже думаю не будут ли хаять снова
Andots
ахах :) Да не, на самом деле не злые, и думаю все как вы выразились "уже потрахались" . Ну просто форум сам по себе для других проблем. Данный вопрос нужно думаю задавать разработчикам Vray, ну вы сами то как считаете какой на него здесь ответ будет? Ваш вопрос если перефразировать звучит как "Чу.. А что это там гудит за стеной? Уж не демоны ли окоянные пришли по мою душу" Я юморю, но если перефразировать так и есть.. Если у вас конкретная проблема или что то подсказать, то без вопросов, тут всегда подскажут и помогут. А так, ну к чему такие вопросы и к чему вам ответы на них. Равно как и вопросы из разряда что гугл даст ответ за 2 сек. В большинстве своем ваши вопросы если перефразировать звучат как "А почему в синьке вот так, а в майке не вот так" ну что вам ответить кроме как "покачену"...
Блин, ну форум это, сидит человек, столкнулся с проблемой, поискал в гугле, не нашел (или с формулировал неверно в поиске) вышел сюда и написал " пипл хелп, вот не могу разобраться в том то, в том то". Да все помогут если знают ответ. Ваши же вопросы если брать по веткам из того разряда что отвечай, что не отвечай сути 0. Начнем с того что на конкретные ваши вопросы с некими проблемами лично я исходя из своих знаний старался дать нормальный ответ.
Болач
да вы мне не раз отвечали и нормально тоже я благодарен.
Конкретно насчет этого вопроса конечно в гугле этот вопрос найти невозможно
Я спрашивал "У всех ли так же?". Можно было бы просто проверить у кого есть вирей. Или может я тупо не так материал для BG готовил.
Но я уже разобрался, это оказалось автосохранение изображений так загружало.
