Maya и ноутбук Toshiba P105-S9312
Sahafa
Господа, вот решил прикупить ноутбук для выездных так сказать сессий в Maya на даче.
Параметры таковы:
Processor and Chipset
Intel® Centrino® Mobile Technology featuring:
• Intel® Core™ Duo Processor T2500 2.0GHz, 2MB L2, 667MHz FSB
• Mobile Intel® 945PM Express Chipset
• Intel® PRO/Wireless 3945ABG (802.11a/b/g)
Memory
Configured with 2048MB PC5300 667MHz DDR2 SDRAM (both memory slots may be occupied)
256MB(min)/4096MB (max), 2 memory slots using 256MB, 512MB, 1024MB or 2048MB PC5300 DDR2 667MHz SDRAM, dualchannel support requires two memory modules of same capacity and clockspeed
Hard Disk Drive
200GB (4200 RPM) Serial-ATA (SATA) hard disk drive; 12.5mm height
Fixed Optical Disk Drive
DVD SuperMulti (+/-R double layer) drive supporting 11 formats
Maximum speed and compatibility: CD-ROM (24x:read), CD-R (24x:write), CD-RW (10x:write), DVD-ROM (8x:read), DVD-R (Single Layer, 8x:write), DVD-R (Double Layer, 2x: write), DVD-RW (4x:write), DVD+R (Single Layer, 8x:write), DVD+R (Double Layer,
2.4x:write), DVD+RW (4x:write), DVD-RAM (5x:write)
Display
17.0” diagonal widescreen TruBrite™ TFT active-matrix LCD display at 1440x900 native resolution (WXGA+)
Graphics
PCI-Express™ x16 graphics subsystem, featuring:
NVIDIA® GeForce™ Go 7900 GS with 256MB DDR3 discrete graphics memory
Sound
Built-in harman/kardon® stereo speakers
SRS Labs audio enhancements
o SRS TruSurround XT® virtual surround sound
o SRS WOW™ stereo enhancement
16-bit stereo software sound
o Intel® High Definition Audio
Sound Volume Control Dial
Input Devices
• Keyboard
o 103 key US keyboard with 10-key
o Hot Key Functions (Fn)
o Windows Key Function
o Application Key Function
• Dual Mode Pad pointing device
• Control Buttons:
o Internet button to launch default browser
o Express Media Player CD/DVD launch button
o CD/DVD control buttons (Skip to Previous/Next Track, Play, Stop)
Communications
Toshiba V.92 software modem
Intel® PRO/100 VE Network Connection - 10/100 Base-TX Ethernet
Integrated Intel® PRO/Wireless Network Connection 3945ABG (802.11a/b/g)
Bluetooth® version 2.0 plus Enhanced Data Rate (EDR) with Toshiba Bluetooth driver software
Expandability
2 main memory slots. Both slots may be occupied.
1 PC Card slot support 1 Type II, PCMCIA R2.01, PC Card16, CardBus
ExpressCard™ slot supporting ExpressCard/34 and ExpressCard/54
5-in-1 Bridge Media Adapter
o Secure Digital, Memory Stick™, Memory Stick PRO™, Multi Media Card, xD Picture Card [shared slots]
Ports
• Video
o RGB (monitor) output port
o S-Video output port
o DVI-D output port
• Audio
o S/P DIF output port (shared with headphone port)
o Microphone input port
o Headphone output port
• Data
o i.LINK(tm) IEEE-1394
o Universal Serial Bus (USB v2.0) – 4 ports
o RJ-45 LAN port
o RJ-11 modem port
Physical Description for this Product Series
Dimensions (WxDxH Front/H Rear): 15.5” (394.0mm) x 10.8” (275.0mm) x 1.41” (35.9mm)[F]/1.64” (41.9mm)[R] without feet
Weight: Starting at 7.1 lbs (3.2 kg) depending upon configuration
Indicators: Power, Primary HDD Access, ODD Access, Caps Lock, Arrow Mode, Numeric Mode, Main battery charging status,
Sleep/Suspend Status, Wireless Communications
Chassis Description
o Case material: Polycarbonate ABS
o LCD Cover Color: Sunlight Copper
Physical Security
o Slot for cable lock
o Items protected by a screw: Memory, Main HDD
o Fingerprint Reader (includes software for password and identity management)
Software Security
o Passwords: User power-on password, supervisor password
o Hotkey locks: Screen Blank
Power Supply
120W (15V x 8A) Auto sensing external AC Adapter, 100-240V / 50-60Hz frequency (Universal) input.
Dimensions (WxDxH): 5.9” (150.0mm) x 2.6” (65.0mm) x 1.2” (30.5mm)
Weight: starting at 1.4 lbs (650 g)
Battery
9-cell (6000mAh) rechargeable, removable Lithium Ion (Li-Ion) battery pack
Battery Life (measured by MobileMark™)14
o 9-cell battery: 2 hours, 00 minutes
Recharge Time
o Main Battery Off/On – approximately 4.0 hrs/approximately 12.0 hrs
BIOS
ACPI v1.0b, PNP v1.0a, VESA v2.0, DPMS v1.0, DDC v1.0, SM BIOS v2.4, PCI BIOS v2.2 support
Вобщем вызывает сомнения процессор, может ли он тянуть 3D графику?
shidoxx
процессор потянет без сомнений а вот видео карта не очень то годится плюс цвета монитора тоже будут не очень.....
shidoxx
Ну они все в ноутах урезаны впринципе можно и на этом работать конечно....это не худший вариант.... сколько стоит такая конфигурация ? есть ноуты с 8 поколением нвидии они вроде быстрее или можно посмотреть с про карточками ноуты HP выпускает такие FireGL и QuadroFX, может еще кто но не знаю точно
на ebay видел восстановленый HP за 1600 $ с FireGL видеокартой (но и эти про карты они тоже урезаны)
shidoxx
У меня ноут с процессором Т5600 (1.83 Ghz, 2 Mb, FSB 667 ) двуядерник рендерит быстрее ровно в два раза чем мой десктопный Пень4 3,2 Ггц с НТ.
А видео карта 7600 немного притормаживает 7900 в два раза быстрее так что впринципе может Вам и хватит как раз такой видео карты.... но всё равно это далеко от уровня 8800GT GTX
Sahafa
ОК, всё понял. Спасибо. Конфиг этот стоит 46000р., значит всётаки стоит покупать, просто у меня дома на настольном стоит ещё более старая видеокарта GF FX 5500,нормально, тянет. А до этого была 5600, но сгорела.
Здравствуйте, уважаемые! Решил не создавать новый топик - все равно о ноутбуках... В общем сегодня я стал счастливым обладателем такого агрегата:Acer Aspire 7520G-502G16i. Вкратце о начинке:AMD Turion 64x2 TL60 2.0Ghz, RAM 2048Mb, HDD 160GB, 17"WXGA+ (1440 x 900 pix), nVidia GeForce 8400M до 896Mb, DVD±RW (Supermulti). Отвалил 34.200 руб. А вопрос такой: товарищи продавцы порекомендовали для повышения производительности снести родную Vista и поставить ХР. Но дело в том, что в этих(незнаю, как в других) ноутбуках загрузочные файлы Vista и дрова находятся на специально отведенной части жесткого диска, и при установке ХР они должны погибнуть - ищи мол дрова в инете и т.д. Меня интересует, стоит-ли овчинка выделки: с одной стороны Vista и удобство пользования, но потеря производительности; с другой ХР с гемором по поиску и установке дров, 64-битной ХР на аглицком(говорят на русском нету) но зато с приростом производительности... Мобть кто вставал перед таким выбором?
shidoxx
виста вроде батарею жрет только, а по производительности наверное одинаково ...... я бы не удалял висту плюс в ней директ икс 10 а в хп нету, тем более онлайн апдейты есть..... хоть её многие и критикуют, но не так страшен черт.....
Миша Ершов
Модератор форума
Смотря какой вид работ собираетесь выполнять. У меня гораздо более слабый бук, и вполне хватает.
Компания asus даёт официальную документацию по установке XP на свои ноутбуки. Причем в списке моделей указана возможность установки XP на каждую модель. Может быть отдел поддержки азера тоже до этого додумался?
