Maya 6.5 beta
Валяется в сетке.
5 частей:
http://www.9iv.com/down/down.asp?id=362&no=1
http://www.9iv.com/down/down.asp?id=362&no=2
http://www.9iv.com/down/down.asp?id=362&no=3
http://www.9iv.com/down/down.asp?id=362&no=4
http://www.9iv.com/down/down.asp?id=362&no=5
качается плохо. С ослика сегодня через 2-3 часа получу.
Могу вывалить на фтп.
General improvements:
* Alias DirectConnect included with Maya
* FBX plug-in included with Maya
* CGFx plug-in (Windows)
* Subdivision surfaces heads-up display
* Improved Layer Editor navigation
* Maya Web browser improvements
* Improved wheel mouse support
* Scaling a light or camera locator
* Environment variable expansion in Maya file browser
* Create new layouts in the Component Editor
* Adding custom shared shelves
* Virtual Memory limit of Maya (Windows)
Modeling improvements:
* Soften extruded polygon edges and faces
* Soften split polygons
* Polygon Bevel improvements
* UV Texture Editor improvements
* Subdivision surface improvements
Animation improvements:
* New animation clip per channel offset controls
* New channel state controls
* Improved animation-constraint blending
* Custom playback speed
Character Setup improvements:
* Improved Copy Smooth Skin Weights
* Bind skin to non-joint objects
* Prevent attachment of zero-weighted smooth skin influences
* Maintain Max Influences
* Add influence objects at any pose
* Automatic joint radii according to bone length
Rendering improvements:
* Improved Hypershade navigation
* New flags for the Command Line Renderer
* Maya vector rendering
* Maya hardware rendering
* mental ray for Maya rendering
Other improvements:
* Support for renaming per particle fields
* Specifying which particle systems to cache
* Artisan improvements
* 3D Paint Tool improvements
* Fluid Effects improvements
* Fur improvements
* Hair improvements
* Cloth improvements
* Maya browser can get data from Maya
* FCheck improvements on Mac OS X
* Additional utilities on Mac OS X
* Improvements to IMF
* New MEL commands and flags
* API and Devkit improvements
etc , ....
Все заливается, при условии ДАЖЕ наислабейшего трафика, напр. как у меня
160 - 128 кбит/с ВСЕГО за 4ч. 15 мн. !!!!
СуперССылки!!!
Проверка 6.5 наверно того стоит - ну хоть посмотреть...
а вот мне не повезло: скорость 5 - 6 кбит/с
на 10-12 мегах - вылетает(
FlashGet для этого существует, он поддерживает докачку, и вообще ПРЕКРАСНАЯ прога для таких вот задачек.
ТОЛЬКО его и пользую...
БЛИНН....
Для разорхивации запрашивается пароль....!!! (rar-ы)
Blob, или кто-нибудь, знает или может вылечить ЭТО?!
"А счастье казалось так возможным,... так близким"...
Путем нескольких манипуляций удалость таки догадаться(эмпирическим путем) каков у азиатов пароль на эти 5-ть архивов... ВОТ ОН:
http://www.9iv.com/
да..........
Молодчины азиаты, но и ...
Остается одно последнее препятствие перед пробой 6,5 - это Активация...
Старая, для 6-ки не съедается 6,5-ю... :(((
Ей треба свеженькое(ну не воспринимает она 6,0 aw.dat как
Install a product license on this comp...
Видать опять в Мула лезть надо...
Итак, для 6.5 ВСЕ необходимое наличествует:
Pass для архива - см. выше...
а Лицензирование и "Что новенького" приготовила нам 6.5.
положил в Черепаший ящичек(turtle101@mail.ru pass - see....... early topics)
оттуда и забирать... :)
Все РАБОТАЕТ!
Если ее ставить голышом, без старых Preferences - получается такая скромница, аж как боюсь сказать, ну как девственница... и в этом есть опять свой смысл... пересмотреть многое...
Дерзайте и УДАЧИ ВСЕМ!
И пусть никто не уйдет обиженный!
Bests.
validat.
Привет!
Напиши пожалуйста как влезть в "Черепаший ящичек" за Лицензированием и "Что новенького" ?
Каой там Пароль?
Или если можеш пошли на lesnic@gmail.com
Вот я тут несколько книг увидел по Майке.
Может будет интересно.
http://www.anwarica.com/maya/
Спасибо!
3D_Man
Парни кто скачал, делитесь инфой как она, как там чо, я просто не хочу какчать почти 250мг. посравнению с v6.0 которая весит ококло 150мг. я лучше релиза дождусь!
Быстрее она - ВОТ главное, что пока попробовал - особливо в динамике!!!!
А то в 6,0 для таких-же операций по продвижению анимации в окошечке - замучаешься ждать, а тут раза в 1,5 - 2 быстрее происходит.
Наверное у кого как...
У меня Атлон XP 2400+
Пока так.
#17
пацаны и в правду выложыите МАУА 6.5 КУДА НИБУТЬ!
например в какой FTP...
#18
на этом сайте есть ещё один линк.
http://www.9iv.com/down/down.asp?id=362&no=6
это ключик... и dat и почемубы сразу линк не дать....
#19
Не сможешь на свой ФТП-ик положить, я могу закачать - тока скажи куда и как, ведь все уже ЕСТЬ :)))
/* если ошибся в нике - umnikamrod - прости... :) */
Спасибо за твой ФТП-ик- одно осознание оного, что он есть не только у Синьщиков.....
#20
MR ОЧЕНЬ адекватнее к Майковским шейдерам относится теперь,
ОЧЕНЬ Адекватно!!!
P.S. не о шейдерах...
/* Вот что он пишет в Output Window при своей загрузке:
mental ray: got 8 satellite CPUs.
mental ray for Maya 6.5
mental ray: version 3.4.1.5, 27 Dec 2004
