Link
Тема в разделе "Общие вопросы", создана пользователем -, 10 апр 2002.
    Всем привет!!!!
    столкнулся с проблемой.............
    как привязать объект к вершинам другого объекта
    (к примеру корабль на волнах качается.......)
    буду признателен за помощь
    посмотри скрипт SubLink здесь:
    http://dg.cgnation.com/scripts.htm
    или используй:
    Attachment Constraint
    Animation menu > Constraints > Attachment Constraint
    The Attachment constraint is a Position constraint that attaches an object's position to a face on another object (the target object doesn't have to be a mesh, but must be able to convert itself to a mesh).
    By keying different attachments over time, you can animate the position of an object over the irregular surface of another object, even if that surface is changing over time.
    удачи ;)
    лучше всего это делает digimation glider. ищите и обрящете.
    Удачи.
    PlayStation.
    Real game is coming !!!
    спасибо.............=)
    Vot jeshchio odna ssylochka (novyj script kak raz dlia tebia):
    http://www.scriptspot.com/start.htm
    Follow Surface 1.1 3ds max 4.x
    Here's a script to allow an object to follow the contours/etc. of another object. It's called 'Follow_Surface' and it will enable you to have an object follow a surface even if the surface is animated. You can also follow the surface with a time delay (like a buoy does when it's floating on water).
    Written by Shawn Lewis.
    4/10/2002
