Time independent - when this option is On, the rQMC pattern will be the same from frame to frame in an animation. Since this may be undesirable in some cases, you can turn this option Off to make the rQMC pattern change with time. Note that re-rendering the same frame will produce the same result in both cases.
переводить впадлу но делает этот параметр тоже самое
