Можно использовать Expression для position движущегося слоя.
center=this_comp.layer("Center").position;
radius=80;
angle=time*2;
x=radius*Math.cos(angle);
y=radius*Math.sin(angle);
add(center, [x, y]);
("Center" - вспомогательный слой с центром в центре вращения. Радиус и период соответственно меняешь как нужно.).
Или можно использовать motion math:
// Eliptical motion
// This script applies a circular or elliptical motion to a
// target layer. It uses a secondary 'construction' layer
// to determine both the bounds and center of the
// circular/elliptical motion. The construction layer's
// position and scale can animate over time, creating
// some fairly elaborate motion paths.
// LAYER PROPERTY CHANNEL
// 1: Target layer doesn't matter doesn't matter
// 2: Construction layer doesn't matter doesn't matter
target = pop_layer(1);
construct_layer = pop_layer(2);
// # of seconds per full revolution
period = 2;
// The secondary layer's scale * its dimensions = the ellipse's radii.
// Note: motion will be counter-clockwise if both x&y scales are positive or negative;
// motion will be clockwise if one scale is positive and the other negative.
xradius = (layer_size(construct_layer)[X] /2) * (value(construct_layer, scale)[x]/100);
yradius = (layer_size(construct_layer)[Y] /2) * (value(construct_layer, scale)[y]/100);
// Calculate basic elliptical motion
xposition = sin(deg_to_rad(360 * time()/period)) * xradius;
yposition = cos(deg_to_rad(360 * time()/period)) * yradius;
// find construction layer's center
xcenter = value(construct_layer, position) [X];
ycenter = value(construct_layer, position) [Y];
// Assign the elliptical motion to the target layer
value(target, position) [X] = xposition + xcenter;
value(target, position) [Y] = yposition + ycenter;
Сохрани с расширением mm и пользуйся.
