Нет форума по Бразилю, я поэтому сюда...
Вот строчки из мануала, но я все осмыслить и перевести не могу
8.3. How do I create light-casting objects?
Creating self-illuminating objects is accomplished most easily by starting with a standard material. In the material editor, set the material's self-illumination to 100. Set the material's diffuse color to pure white and then apply an output map to the diffuse slot. In the output map, you should increase the RGB Output to get the object to emit light. Increasing this will cause more light to be emitted. Also, by increasing the size of you object, you will increase the amount of light it will cast.
кто знает КАК? Подскажите плиз...
