Всем привет!
Кто-то разобрался с нодой Catcher? В шестом фьюжене, она заменила ноду (PAW3d), но работает совсем по другому принципу.
Напоминаю, PAW3d позволяла сохранить альфа от текстуры, которая проецируется. В шестом этой ноды нет, а в мануале пишет:
А здесь описание подключения:
и ещё
Делаю всё как написано - результат пустой экран.
Если делать light projection всё работает, кроме альфы.
Может у кого-то есть рабочий скрипт по кетчеру?
Код:
Also available is the Catcher tool, renamed from Paw3D which was released as a special eyeon plug-in for
version 5.3. This tool clearly converts a Projection from being light based into a texture which enables
alpha information to be projected onto a 3D model and form a hole though which other geometry could
be seen. The Catcher is not restricted to the diffuse input of a material, and so it is possible to project
specular intensity maps, or even reflection and refraction maps onto geometry.
Код:
By connecting the Catcher to the diffuse texture map of the material applied to the Image Plane, and then switching the projection from light or ambient light mode to texture mode, Fusion knows to apply the projected image as a texture map. When using this technique, the windows would become transparent, and it would be possible to see the geometry behind the window.
Код:
One useful trick is to connect a Catcher tool to the Specular Texture input on a 3D material tool (such as a Blinn). This will cause any object using the Blinn material to recieve the projection as part of the specular highlight. This technique can be used in any material input that uses texture maps, such as the specular, and reflection maps.
