Как настроить фотоны?
Тема в разделе "Mental Ray", создана пользователем Colorizator, 7 июн 2005.
Модераторы: Alex Kras
  1. Colorizatio
    Colorizatio Знаток
    При использовании Directional Light фотоны считаются косячно. Большие круги на горизонтальной плоскости и дикая засветка.
    С Point Light всё нормально.
    Работаю в майке и пока еще чайик. Буду рад, если поможете, спасибо.
  2. Colorizatio
    Colorizatio Знаток
    Caustics don't work with a directional light
    Don't use directional lights for photon emission. Although you can render caustics and global illumination with a directional light source (that is, all the necessary attributes exist), we recommend against it. Because a directional light has no origin, it will unnecessarily shoot photons into a scene where they aren't needed, thereby increasing render times dramatically.
    If you must render a directional light with photon emission (with mental ray for Maya), ensure that objects are marked properly for photon tracing. For more information on photon tracing and problems that may occur, see GI photon maps vs. caustic photon maps.
    Но при использовании Point Light тоже местами видны "левые" круги.
  3. Gordy
    Gordy Активный участник
    Why did you wright in English language, it is not politely!!!
    это всё касается только майки или и макса тоже?
    P.S. блин за последнее сообщение надо давать авард по английскому LOL
  5. rich 4633
    rich 4633 Активный участник
    I guess i can write in english too, but i don't expect everyone to know it, am i right?
    Heh anyway, if you want to learn Maya and know it well, you have to know english as well as you can.
    A guy who has tell that he is an artist of CG without having knowledge of Englihs ia an old fox.
