Как быстро переключаться КАРАНДАШ-ЛАСТИК?
В хелпе ничего не нашел :(
никаких shortcut
А каждый раз выбирать кисть - долго. Есть наверно какая-то хитрость?
Keyboard Shortcuts PAINTER.
File Menu
New<CTRL> + <N>
Open<CTRL> + <O>
Save<CTRL> + <S>
Print<CTRL> + <P>
Exit<ALT> + <F4>
Edit Menu
Undo<CTRL> + <Z>
Redo<CTRL> + <R>
Cut <CTRL> + <X>
Copy<CTRL> + <C>
Paste<CTRL> + <V>
Edit Floater <CTRL> + <T>
Selection Menu
Select All<CTRL> + <A>
Deselect All<CTRL> + <D>
Select Inverse<CTRL> + <SHIFT> + <I>
Move Selection <V> + Drag
Quick Mask <Q>
Palettes
Show/Hide Palettes<TAB>
Show/Hide Shapes Palette<ALT> + 6
Show/Hide Swatches<F3> or <ALT> +5
Show/Hide Color Palette<F4> or <ALT> + 4
Show/Hide Command Panel<ALT> + 3
Show/Hide Tools Options<ALT> + 2
Show/Hide Tool Palette<ALT> + 1
Presets Tab<F5>
Brushes & Paint SettingsTab<F6>
Layers Tab<F7>
Lighting Tab<F8>
Floaters
Drop Floater<ENTER>
Delete Floater <ESC>
While Painting
Brush Size <CTRL> + Drag up/down
Transparency<CTRL> + Drag left/right
Brush Aspect<SHIFT> + Drag up/down
Brush Angle<SHIFT> + Drag left/right
Move Brush Preview<SHIFT> + <CTRL> + Drag
Gestures
UndoRMC + Drag left
Redo RMC + Drag right
Color PaletteRMC + Drag up
Show/ Hide Palettes/ MenusRMC + Drag down
Channel Selection
Color<1>
Bump<2>
Shine<3>
Colors
Add Color <SHIFT> + Click
Delete Color<CTRL> + Click
Reset to default (black/white)<D>
Swap foreground/background<X>
Tools
Eraser<E>
Freehand<B>
Text<T>
Fill<K>
Spline<G>
Spline Select<H>
Clone<S>
Line<N>
Rotate LightHold <L> + Drag
Eyedropper<I> or <ALT> + Click
Selection Tool<M>
Magic Wand<W>
Pan<P> or <SPACEBAR> + Drag
Move<V>
Zoom<Z>
RotateHold <R> + Drag up/ down
SplineTool
Append VertexClick off spline to create
Insert VertexClick on spline to insert
Delete VertexClick on existing to delete
Spline Select Tool
Select Vertex toolDRAG to select vertices
Add to vertex selection <SHIFT>+ DRAG
Subtract from vertex selection <ALT>+Drag
Intersect the vertex selection <SHIFT+<ALT>+DRAG
Spline Transform Tool
Move, Rotate and ScaleSpline selected + Drag
Lock Scale Aspect <SHIFT>
Line Tool
Angle Snap<SHIFT> + Drag
Selection Tools
Add to Selection <SHIFT> + Drag
Subtract from Selection <ALT> + Drag
Transform Selection <CTRL> + <T>
Delete Selection<DELETE>
Pan Tool
Pan<SPACEBAR> + Drag
Reset PanPan tool + Double Click
Zoom Tool
Zoom In<Z> + Click or <CTRL> + <SPACE> + Click
Zoom Out Zoom tool + <ALT> + Click or
<CTRL> + <ALT> + <SPACE> + Click
Zoom ExtentsDouble click with Zoom tool
Zoom Dynamic<SHIFT> + Click
Zoom Sub-menuZoom tool + RMC
Rotate Tool
RotateHold down <R> + Drag up/ down
Reset RotateHold down <R> + Double click
Rotate Sub-menuRMC canvas
Сппрашивайте, отвечу. Олег Беседин
http://www.besedin.photographer.ru
http://www.besed.photographer.ru
http://www.besed.irnet.ru
Alex Romanets
А вы проверяли работоспосбность Eraser<E>, у Вас какой Painter?
У меня в 8 эта команда выполняет поворот холста
