Камрады, помогите чайнику! Собственно, задача предельно проста - каким оптимальным образом найти нужный полигон ?
// Error: polyToSubdiv1 (Poly To Subdiv Node): The conversion to a subdivision surface failed:
// This polygon contains an interior vertex connected by less than 3 edges.
// To fix the problem, either remove the edge with the interior vertex, or subdivide the polygon so that the interior vertex has at least 3 edges.
// The indices of the vertices in question are: 698, 2849. //
