файл не открывается
Тема в разделе "Adobe Illustrator", создана пользователем -, 16 апр 2003.
    Возможно, кто-то уже сталкивался.
    Acrobat PDF File Format is having difficulties. The file is damaged and could not be repaired.
    Можно ли восстановить?
    Методы предложенные на этом форуме не помогают.
    Заранее спасибо.
    Убрать галку PDF compatible что-то там. В диалоге save as.
    Привожу рецепт без перевода, в оригинальном виде:
    When Illustrator began using PDF as its native format, it effectively became impossible to edit those files in a text editor when problems arose (which you were able to do when EPS was the native format).
    Illustrator 10 has a «hidden feature» that allows you to recover corrupt files. Here are the necessary steps:
    1) Open the preferences file and look for the entry named
    «enableContentRecovery», change the value from 0 to 1. This turns on the
    feature.
    2) Launch Illustrator and choose «File>Open». Select the file from which you
    wish to recover the roundtrip information.
    3) Click «OK» while holding down the command, shift and option keys
    (control, shift and alt on Windows).
    Following this procedure will result in a new empty document in Illustrator.
    This you should just close without saving. In addition the roundtrip
    information from the file is extracted to a new file in the same directory
    as the original. The new file is given the same name as the original
    preceded by an underscore character.
    Once the roundtrip information has been extracted it can be viewed in an
    editor and any problems corrected. The corrected file can then be opened in
    Illustrator. Note that images in the file are saved as binary. Therefore the
    editor used to modify the file must preserve binary data.
    спасибо за ответ. Интересная возможность, но мне не помогла. Погрустил, погрустил и сваял все заново.
