Eyeon fusion 5.01
Григорий Чаленко
Куратор форума
Eyeon:
Fusion 5.01 is now available for download from our website. This patch addresses several stability improvements and enhancements to Fusion 5.0. Please read the release notes for a complete list of changes.'
http://www.eyeonline.com/downloads/release...enotes_501.html
NEW FEATURES and ABILITIES
Fusion now loads 32bit float PSDs from Photoshop CS2.
Added a new "Import Transform..." button in the transform tab of most 3D tools, for importing transformations from supported 3D file formats.
The 3D software renderer can now output z-depth, z-coverage, and BG color channels.
Dropping a camera on a view (from a toolbar or a bin) will now set it up automatically to match the current view camera, and starts viewing through it. Also added a "Copy View to" submenu to the Camera submenu to copy the current view position/angle to the chosen camera/light/other object.
Added very basic texture mapping to 3D text.
Fusion can now read 10bit RGBA DPX files.
Fusion now supports any macro as a View LUT. Just expose the controls you want, save it in the Fusion:LUTs folder, restart Fusion, and select it from the list in PrefsView. New .setting files added to the LUTs dir are now recognised & loaded on the fly, without having to restart Fusion.
Hold down Shift while choosing Set Render Range or dragging a tool to the time ruler to also set the Global Range to the tool's valid extent.
Tracker patterns can now be deleted!!!
New grain processing. Has a new scale function that scatters/jitters the generated grain pattern, so as it gets larger it doesn't look as blocky.
Fusion can now read DV OMFs if the AVID DV QuickTime codec is installed. Writing out DV OMFs is not possible at this time.
Fusion can now import old DF4 style .lut files.
Added rotation and pivot inputs to particle 3D sphere regions
Blobs should cast shadows now in 3D correctly.
Motion blur is now available on particles IF the settings for the pRender tool and the Renderer3D tool are the same.
Added Wavefront obj files support.
Added displayed depth range to PrefsView, so you can more easily deal with Z buffer data outside our default -1000..0 range (e.g. from Maya, LW etc)
Removed the Grid toolbar button from the display views, and added a LUT toolbar button. Click to toggle LUT enable, popup for a list of LUTs.
Added the ability to use macros in view LUTs (save as a .setting file in the Fusion:\LUTs folder).
Can now double-click in a view to play the current preview (if there is one), again to stop, hold shift for reverse playback.
Can right-drag to scrub the current preview.
Added a Play toolbar button to bottom right corner of a preview. Click to play/stop, shift-click to play reverse.
Added current frame text to bottom right corner of a preview.
Added the ability to apply similar view settings to a number of bin subfolders.
Added the ability to specify per-user library root from BinSecurity prefs
Generic files can now be added to the bins. These objects can now be 'opened' (by associated app) by either double click, or Open context menu. Generic files will attempt to use the shell/explorer icon for the file.
Settings can use an icon from a .bmp file of the same name.
One can now network render a composition even if the path to the composition is valid only to the render manager. The render manager now opens the composition and streams it to each of the slaves. Paths used for footage in the composition still need to be valid for all slaves though.
Григорий Чаленко
Куратор форума
- Yeah, yeah baby! :)
- Сергей Чук, это для тебя! :)
- Нет слов :)
- Дело Комбашена живет :)
- А еще скоро мы научимся форматировать диски и принимать почту :)
- Полезная вещица
шшшо?
dpx с альфа каналом?
революция какая-то! :)
только битности маловато :(
Даёшь float!
svet
УРА! тот проект, что бесмысленно валился, зажил, можно продвигатся дальше
это что, утка что ли?
ссылка мертвая, на офсайте ни слова (как обычно:)
svet
Gringo, у тебя версия от iNFERNO?
обнаружился один бак (тоже было в ДФ4.01 от пародокса) при работе с полями временами кадр прыгает то в поле, то в фулфрам. Еще при работе с полями нет З буфера. Чтото с форматами поди недокручено или скорее отрезано:(.
но все равно даволен, пока не разу не завалил, хотя кручу уже навороченые проекты с предыдущих проб.
Ох еслибы еще примат:)
кстати заходил на спидсикс они анонсируют на первой страничке бету монстров под ДФ5, но в качалке не нашел.
Григорий Чаленко
Куратор форума
Да, инферно.
Но я пока не ставил: буду испытывать на новых проектах.
Без примата, монстров и крокодавов обойтись трудно.
о глюках....
b-spline to besie и наоборот работает так же некорректно - чаще падает. Особенно когда меняешь веса точек b-spline.
короче с b-spline как было невозможно работать - так и есть. А жаль. Остальные глюки из тех что замечал вроде исправлены.
#16
вопрос вдагонку. Где в свойствах указывается размер кнопок инструмента во вьюпортах по умолчанию? У меня они большие по умолчанию и как это лечить я не нашел.
tyutya_bee
Да, прочел правила и стер прямой вопрос. Но в чем проблема догадаться можно, конечно...
