э-э-э-э-э!!!! А как теперь....
А как теперь в трехе превью на нод сделать? Теперь кнопка Р в рендер три не работает!!! Кто знает?
Where did the p key preview go?
Due to instability issues, the p key preview is no longer an officially supported feature of SOFTIMAGE|XSI. The function involved a large amount of “unwiring” and “rewiring”, and was often the cause of scene problems.
It has not been removed, however, only unmapped. To use the p key preview, you need to map it back to the p key using the keyboard mapping dialog box.
Should you decide to remap the p key preview, use it with caution
Make sure to save a backup copy of the scene before using the preview function.
Choose File > Keyboard Mapping from the main menu bar. The Keyboard Mapping dialog box appears.
You cannot change the default shortcut key templates; you can only modify keyboard shortcuts from your own template.
Do one of the following:
Click the New button to create a shortcut key template and enter its name.
or
Select an existing editable shortcut key template from the Key Map combo box.
In the Group box, choose Render Tree.
In the Command box, drag-and-drop the Node Preview command down to the P key on the keyboard graphic below.
The new shortcut key appears in the column to the right of the command name in the Command box. Any previous key association is removed.
