Experimental: Fusion can now use standard OHCI Firewire ports as an output for viewing tools. This has not been extensively tested yet, and may require recent versions of DirectX and Windows. You will also need a DV device plugged into the Firewire port. To use this feature, create an environment variable called "DF_DV", set it to "true", and restart Fusion. When a connected DV device is set to the appropriate mode, it should show up on Fusion's View On submenu.
