What’s new in CorelDRAW
CorelDRAW includes new features and enhancements that will make your work easier.
Enhanced support for Scalable Vector Graphics (SVG) files
You can choose a variety of new options when exporting a drawing to the SVG file format. You can choose a Unicode encoding method. You can also embed information in an SVG file, or store information in externally linked files. The SVG color palette available in the application lets you choose SVG colors. For information about SVG files, see “Scalable Vector Graphics” in the Help.
Export for Office
CorelDRAW lets you optimize drawings for export to Microsoft Office or WordPerfect Office. For more information, see "To export to Microsoft Office or WordPerfect Office."
Multiple language support
CorelDRAW allows users to exchange files effortlessly, regardless of the language or operating system in which the file was created, ensuring that text displays correctly. For more information, see "Encoding text."
Dynamic guides
You can display dynamic guides to help you precisely position, align, and draw objects relative to other objects. Dynamic guides are temporary guides you can pull from the following snap points in objects — center, node, quadrant, and text baseline. For information, see "Using dynamic guides."
Drawing using shape recognition
CorelDRAW lets you can draw freehand strokes that are recognized and converted to basic shapes using the Smart drawing tool. CorelDRAW automatically smoothes any unrecognized shapes or curves drawn with the Smart drawing tool. For more information, see "Drawing using shape recognition."
Snapping enhancements
While you move or draw an object in CorelDRAW, you can snap it to another object in a drawing. You can snap an object to a number of snap points in the target object. When the pointer is close to a snap point, the snap point is highlighted, indicating it as the target that the pointer will snap to. For more information, see "Snapping objects."
Text alignment
CorelDRAW has enhanced text alignment. You can align text objects to other objects using the first text baseline, last text baseline, or the bounding box. For more information, see "To align text to an object."
Copying object properties, transformations, and effects
You can use the enhanced Eyedropper and Paintbucket tools to copy color, object properties, effects, and transformations from one object to another. For information about using the Eyedropper tool, see "Copying object properties, transformations, and effects."
Virtual segment delete tool
You can delete portions of objects, called virtual line segments, that are between intersections. For more information, see "To delete a virtual line segment."
Improved file compatibility
CorelDRAW has improved compatibility with many industry-standard file formats, such as Hewlett-Packard Plotter (PLT), AutoCAD Drawing Interchange Format (DXF), AutoCAD Drawing Database (DWG), Computer Graphics Metafile (CGM), Microsoft Word Document, and many more. For more information, see "File formats."
Enhanced symbols
Symbols are now easier to work with in CorelDRAW. The Library is now called the Symbol manager, allowing you to easily work with external symbols and symbol libraries. To simplify distinguishing between a symbol and an object, the selection handles around a symbol are now blue. As well, the controls for editing symbols are easier to access. For more information, see "Working with symbols."
3-point drawing tools
Cursor improvements to the 3-point drawing tools let you easily specify width and height as you draw rectangles, ellipses, and curves. For more information, see "To draw a rectangle by specifying height and width", "To draw an ellipse by specifying width and height", or "To draw a curve by specifying width and height."
__________________________________________
Это официальная информация, а вот неофициальная (впечатлений море):
http://www.graphics.ru/forum/read.php?f=9&i=9401&t=9401
http://forum.rudtp.ru/showthread.php?t=5370
