ya dumayu sto eto mozno pomogit b tvojem problemu
Actually, there's some experimental Firewire DV support in 4.03 (DF and
DFX+). It's not officially supported yet, but for those that want to try it
it out, create an environment variable (Control Panel/System/Advanced)
called "DF_DV" (case is important), set its value to "true", then restart
DF.
Plug in a DV camcorder or similar to your Firewire port, and you should see
a new item on your View On submenu. (*edit* The camera may need to be On already when you start DF)
This env var will also enable the experimental DirectShow writing code,
which you can use to save e.g. long (> 4 GB) DV-format .avi files. You have
to explicitly select DirectShow from the Saver's format list. Note that not
all codecs work, and saving audio isn't supported yet. No capture, sorry.
Other features to come. Feedback very welcome.
I have set up a flow for different layers and have some layers grouped.
now I want to draw a mask or add a bitmap alpha just for the group, how can I do that ?
Insert a matte tool after your group, and apply a garbage mask.
Then drag the bitmap of the alpha you wish to use into the bitmap masks slot.
Hi there,
Here is an incomplete list of (unsupported) DF_* env variables for DF.
