brush na fur
Тема в разделе "Maya", создана пользователем -, 5 окт 2001.
Модераторы: Dark™, Skif
    Ya predpolagayu chto vopros idiotskiy, no ochen6 hochetsya:)
    mozhno li kak-nibud6 na fur podcepit6 brush?
    iz help'a :
    3. If you are painting in a scene, note the following:
    Currently, you can only paint effects on the view plane (the plane that is ortho- normal to the camera view), the grid plane of the perspective view, or on NURBS surfaces.
    Although you cannot paint 3D effects on polygonal surfaces, you can paint 2D effects on them using the 3D Paint Tool, or you can create textures using Paint Effects and apply them to the surfaces. You can also try the following workflows:
    · Use the Particle Instancer with Random turned off to emit particles from your poly mesh, then replace the particles with Paint Effects Strokes. For details, see Using Maya: Dynamics. (Motion blur will not blur Paint Effects strokes with this method.)
    · Place rough, invisible NURBS geometry inside the poly mesh and bind it to the same skeleton. Paint on the NURBS surface and the Paint Effects strokes will grow out the the NURBS surface and through the poly mesh.
    · Bind the CVs of some NURBS curves to vertices on the poly mesh then convert the curves to strokes.
    4. Refer to the lessons in Instant Maya for an introduction to Paint Effects.
    OPPPS , oshibsha , ne ponal vopros
    Eshe raz...chto sdelat6? Podrobnee mozhew6? ;)
    :)mogu
    "attach Brush To Curves" mozhno li kak to primenit6 k Fur-u? hotya bi teoriticheski?
    Э-э-э...всё равно не понял.... ;)
    Где Fur использует кривые? ;))
    Опиши процесс еще раз....что нужно получить в результате?
    Fur kriviye ne ispolzuyet, ya znayu:):):)
    a v rezultate, mne tak razmechtalos6:) rosli bi u menya v Fure ne volosi i sherst6, a travka, listiki, moh, ili voobshe vse chto ugodno. Tolko togda eto uzhe budet ne Fur, a Paint Effect-i.:( Vot takaya grustnaya istoriya poluchilas6...
    Неее....так не получится....Fur - он сам по себе....и заточен на прорисовку именно кривых...
  9. Guest
    Что PaintEffect, что Fur -- это пост-процессы. Тобто рисование поверх отрендеренной геометрии. Подумай сам, как можно эти процессы увязать вместе. Можно сконфигурить brush в PaintEffect напоминающую волосы, но параметры Fur-а, в существующих версиях Майки, с brush-ами пока не пересекаются. Хотя, теоретически это можно было бы реализовать...
    Может в Майа 5.0 ;-)
