Batch Render`s images`re black !!!???
Всем привет. В продолжение темы о рендере....
В силу невозможности рендерить в самой ксюхе - виснет (см. ранний топик), экспортнул в ми2 формат. Экспорт прошел успешно. Вот только далее открываю этот ми-шный файлик с помощью ray3.exe а он мне в своем окне вот такую фигню выдает и складывается:
MI 0.0 warn 122001: standard startup file ray3rc not found
LIB 0.0 error 291025: {LIBS}/legacy.{EXT}: registry entry {LIBS} not found
LINK 0.0 error 191012: object or library {LIBS}/legacy.{EXT} has illegal exten
sion, expected .obj or .dll
LIB 0.0 error 291025: {LIBS}/sibase.{EXT}: registry entry {LIBS} not found
LINK 0.0 error 191012: object or library {LIBS}/sibase.{EXT} has illegal exten
LIB 0.0 error 291025: {LIBS}/base.{EXT}: registry entry {LIBS} not found
LINK 0.0 error 191012: object or library {LIBS}/base.{EXT} has illegal extensi
PHEN 0.0 error 051011: shader "soft_light" not found
PHEN 0.0 error 051011: shader "sib_state_vector" not found
PHEN 0.0 error 051011: shader "mib_texture_lookup" not found
PHEN 0.0 error 051011: shader "sib_uvwgen" not found
PHEN 0.0 error 051011: shader "mib_texture_remap" not found
PHEN 0.0 error 051011: shader "mib_texture_filter_lookup" not found
PHEN 0.0 error 051011: shader "mib_bump_basis" not found
PHEN 0.0 error 051011: shader "sib_color_switch" not found
PHEN 0.0 error 051011: shader "mib_bump_map" not found
PHEN 0.0 error 051011: shader "mib_color_alpha" not found
PHEN 0.0 error 051011: shader "sib_setnormal" not found
PHEN 0.0 error 051011: shader "sib_color_8mix" not found
PHEN 0.0 error 051011: shader "sib_illum_phong" not found
PHEN 0.0 error 051011: shader "sib_illum_translucent" not found
PHEN 0.0 error 051011: shader "sib_scalar_to_color" not found
PHEN 0.0 error 051011: shader "mib_refraction_index" not found
PHEN 0.0 error 051011: shader "sib_diffuse_refraction" not found
PHEN 0.0 error 051011: shader "sib_diffuse_reflection" not found
PHEN 0.0 error 051011: shader "sib_shadow_basic" not found
PHEN 0.0 error 051011: shader "sib_illum_photon" not found
PHEN 0.0 error 051011: shader "sib_color_rayswitch" not found
PHEN 0.0 error 051011: shader "sib_illum_photon_fix" not found
...При этом создает всё таки картинку - точнее файл джипеговый (как было указано в настройках в самой Ксюхе). НО ЭТОТ ФАЙЛ АБСОЛЮТНО ЧЁРНЫЙ !!! Ни какой картинки внем нет!
Пробовал какие-то серверы запускать, батники все просмотрел и запустил в папке с самим рэем. Ничего. Несколько раз выдал Синтаксическую ошибку и вообще не стал картинку делать (вероятно виноваты были настройки перед самим экспортом, потому как с новыми настройками этой ошибки не стало).
Понимаю, что какие-то пути не указаны, но какие и куда их вписывать?
И как вообще управлятся с этим рэем. Расскажите, хоть вкратце, хоть намекните в каком направлении искать.Ведь документация огромная к нему и одни описания шейдеров. Чувствую пока не осилю. Мне ведь просто сценку отрендерить без всяких наворотов. Хоть с жалким намеком на ГИ...:)). ПЛЗ.......
Вот именно поэтому и надо использовать ray3xsi*.bat файл который в application/bin лежит
Кинул мишный файлик на этот батник, - вот что в итоге:
MSG 0.0 warn 012704: cannot open C:\users\Alex\Softimage\XSI_2.03\.ray3hosts
from MI_RAY_HOSTSFILE
Чего - то я вероятно не запустил. Может службу какую?
Все разобрался. Нужно было бросать Сам файл сцены и на СкриптКсиАй.бат
Все остальное почему-то выдовало ошибку. Кстати глюк с зависанием рендера в оболочке может быть связан со свопом или его дефрагментацией. В логах ментал постоянно просил добавки виртуальной памяти и ругался в виде ИНФО: икриз виртуал мемори лимит: 5040037 (пять а может больше раз поднимал этот предел)
Может кто-то разбирался в оптимальных настройках системы для рендера? Поделитесь опытом.
Бросать сам файл сцены это то же самое, что и рендерить его нажав на кнопку render, только не запускается gui. Cannot open, это значит не могу открыть, проще говоря файла у тебя такого нет, ну и хрен с ним это же только предупреждение. (Коли инглиш не радной, бабел друг твой дорогой! :) В нем должны быть записаны твои личные настрой, ну а если его нет, то все идет из стандартных.
Предел скорее всего имеется в виду его внутренний предел, а не ситемый и у меня он по умолчанию 768мб, может тебе сцену попроще сделать?
Да я понял, что это только предупреждение, да вот после него он делать то уже ничего не хочет. То есть остается открытым это окошко и больше уже ничего не происходит.
А как ты эти 768мб настроил и где (в смысле ты ж про ксюхин внутренний предел говориш? Потому как системный своп у меня макс\ мин - 1гб)
