Rhinoceros 3.0 & Flamingo 1.1 (c) Robert McNeel & Associates
date: 14 jan 2003
type: modeling/rendering
Description:
Rhino can create, edit, analyze, and translate NURBS* curves,
surfaces, and solids in Windows. There are no limits on complexity,
degree, or size. Rhino also supports polygon meshes.
Special features include:
-Uninhibited free-form 3-D modeling tools like those found only in
products costing 20 to 50 times more. Model any shape you can imagine.
-Accuracy needed to design, prototype, engineer, analyze, and
manufacture anything from an airplane to jewelry.
-Compatibility with all your other design, drafting, CAM, engineering,
analysis, rendering, animation, and illustration software.
-Read and repair extremely challenging IGES files.
-Accessible. So easy to learn and use that you can focus on design
and visualization without being distracted by the software.
-Fast, even on an ordinary laptop computer. No special hardware
is needed.
-Affordable. Ordinary hardware. Short learning. Priced like other
Windows software. No maintenance fees.
Flamingo brings the raytrace and radiosity rendering to Rhino.
This plug-in includes:
-Rendering. Photometrically accurate images with reflections, refraction,
diffusion, translucency, transparency, color bleeding, shadows,
depth of field, depth attenuation, ClearFinish,
and indirect lighting.
-Animation Viewpoint animation for walk-throughs and fly-bys, and sunlight
animation for shadow studies.
-Other features Procedural clouds, fractal-generated 3-D plants, procedural 2-D
and 3-D materials, progressive-refinement for quick preview,
and extensive material, plant, and background libraries.
For more information go to:
http://www.rhino3d.com/
http://www.flamingo3d.com/
Install info:
Run keygen from crack dir to generate serials. Thanx to zenith for it
